CCY
Jan 01, 2019Aspirant
How to Block PUBG Mobile on RBR50 or Disney Circle
Hi,
Anyone knows how to block PUBG Mobile on RBR50 router or Parental Control - Disney Circle?
In the Disney Circle, filter level, platforms and categories had set all to "Not Allowed" but PUBG M...
Jan 01, 2019Guru - Experienced User
Not sure as this is a fairly new game. Something you might contact NG support and ask about.
Aside from blocking any Amazon service, only other would be blocking the device entirely.
You might try using Dynamic DNS services like DDNS or OpenDNS and use there services to block apps from connecting. You would be telling the Orib router to use thre DNS IP addresses and anything passing thru there IPs, if you have setup blocking, would or should be stopped...
