CESAR--
Jun 26, 2019Follower
HOW TO BROADCAST THE SSID ON THE ROUTER
HOW TO BROADCAST THE SSID ON THE ROUTER, since the router is already online and working but i can't see it in my WIFI login page
CrimpOn
Jun 26, 2019Guru - Experienced User
This issue has come up a couple of times recently, mostly in connection with Windows 10.
On the Orbi web interface, Advanced Tab, Advanced Settings, Wireless Settings, there is a check box for "Broadcast SSID". If it is checked, then the Orbi is broadcasting SSID. There are separate check boxes for 2.4G and 5G.
If the boxes are checked, then there may be another issue.
