ah1's avatar
ah1
Follower
Jun 07, 2017
How to change 5G channel on Orbi
Hi, I've just installed Orbi RBK50 3 pack on firmware 1.10.1.2 (GREAT wifi pack btw!) I used Netgear Genie app to find the most optimal channels, as you can see from screenshot it recommends channe...
  • st_shaw's avatar
    Jun 07, 2017
    It's a good idea to set the 5G channel to the most optimal choice.  You only get to choose between the four listed though.  The higer channels are not available because the backhaul uses the high channels.
