HaroldCarl
Jan 25, 2019Tutor
How to change Admin as UserID on Orbi RBR50
Security Gap:
I would like to see if anyone is aware of how to change the default UserID "admin" from "admin" to something else on the RBK50 system (RBR50 and RBS50)
Please note, that I a...
ekhalil
Jan 25, 2019Master
You can try the following, on your own risk:
- Please take a backup of your system under >> ADVANCED >> Administration >> Backup Settings, in case you will need it! :)
- Telnet to Orbi router
- root@RBR50:/# config get http_username --> admin
- root@RBR50:/# config get http_loginname --> admin
- root@RBR50:/# config sethttp_username="the username you want"
- root@RBR50:/# config set http_loginname="the username you want"
- root@RBR50:/# config commit
- Repeat the same procedure on the satellite(s)
