apgomez3
Dec 08, 2020Aspirant
How to change DNS settings on RBR50
I’m looking to change my DNS resolver from my ISP to Cloudlfare’s 1.1.1.1. I can’t seem to find where to do this.
Dec 08, 2020Guru - Experienced User
Under Advanced tab/Setup/Internet Setup.
- michaelkenwardDec 09, 2020Guru - Experienced User
For future reference, the manual has a section on this.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. - apgomez3Dec 18, 2020Aspirant
The radial button next to Use These DNS Servers is grayed out and I can't edit.
