WilliamSharpe11's avatar
Mar 12, 2021
How to Change IP Address on a RBR20 Orbi Router?
Hi, I'm wondering if there's any way to reset my IP Address through my Orbi RBR20 Router
  • CrimpOn's avatar
    CrimpOn
    The question is ambiguous.  "my IP address" could refer to:
    • The IP address of the LAN side of the Orbi router itself.
    • The IP address of a particular device that is connected to the Orbi.
    It would help to know what you hope to accomplish by making this change.
    • WilliamSharpe11's avatar
      WilliamSharpe11
      Hi, I think I'm refering to the LAN IP Address - if thats the public IP address that shows up when you search "Whats my ip?" All the devices in my house share this same public IP address from my Orbi RBR20 Router, and I'm wondering if theres a way to change this IP.
      • CrimpOn's avatar
        CrimpOn
        Alas, the Public IP is assigned by the Internet Service Provider (ISP). Most ISP's assign "dynamic" IP addresses to subscribers, which may change from time-to-time. (Unless they pay extra for a "static" IP.  Businesses often do this.)
        There is nothing the subscriber can do to change this.
        Residential routers use Network Address Translation (NAT) to identify each of the individual devices that are "behind" the router so that connections made through the router to internet resources are specifi to the device.
        https://en.wikipedia.org/wiki/Network_address_translation
