apgomez3
Sep 30, 2019Aspirant
How to change the IP range
Is there a way to change the IP range on the Orbi RBR50? If so, how can I do it?
CrimpOn
Sep 30, 2019Guru - Experienced User
On the Orbi web interface, Advanced Tab->Setup->LAN Setup.
The user can define the IP address on the Orbi's LAN side. The default is 192.168.1.1
The range of IP addresses given out by DHCP is any part of a subnet that runs from 1 to 254, such as 1 to 100, 100 to 150, 202 to 212, etc.
Many users set aside IP addresses to use for devices that are always on the network, such as TV's, NAS systems, cameras, etc. and use a specific range of addresses for DHCP.
