apgomez3
Sep 30, 2019Aspirant
How to change the IP range
Is there a way to change the IP range on the Orbi RBR50? If so, how can I do it?
michaelkenward
Oct 03, 2019Guru - Experienced User
What are you actually trying to achieve?
Do you have a problem that needs fixing?
There may be easier solutions.
- apgomez3Oct 03, 2019Aspirant
Good question. I'm not having an issue. I was thinking more from a security standpoint. I was told that one thing to do is occasionally change the IP range from the default.
- CrimpOnOct 03, 2019Guru - Experienced User
apgomez3 wrote:I was told that one thing to do is occasionally change the IP range from the default.
That's a fascinating concept, although it may be more of an "urban myth." If someone successfully gets into an Orbi WiFi network, then they will have an IP address, which immediately tells them the IP subnet. So, even if a person changed from the default of 192.168.1.x to 192.168.55.x, the interloper would be put in that subnet as well.
The bigger issue is with "occasionally." A lot of us have assigned IP addresses to specific devices (for a variety of reasons). Changing the DHCP pool could mean reassigning all of those devices. Not a happy thought.
- michaelkenwardOct 03, 2019Guru - Experienced User
Heaven only knows why anyone would say that.
Your (WAN) IP address on the internet is outside your controls. That's down to the Internet service provider.
Local addresses on your LAN are not much use to anyone in the outside world.
There are plenty of ways to enhance your security. Messing around with IP addresses must be some way down on the list.
What security issues worry you? Been attacked lately?
