apgomez3
Sep 30, 2019Aspirant
How to change the IP range
Is there a way to change the IP range on the Orbi RBR50? If so, how can I do it?
apgomez3
Oct 03, 2019Aspirant
Good question. I'm not having an issue. I was thinking more from a security standpoint. I was told that one thing to do is occasionally change the IP range from the default.
CrimpOn
Oct 03, 2019Guru - Experienced User
apgomez3 wrote:I was told that one thing to do is occasionally change the IP range from the default.
That's a fascinating concept, although it may be more of an "urban myth." If someone successfully gets into an Orbi WiFi network, then they will have an IP address, which immediately tells them the IP subnet. So, even if a person changed from the default of 192.168.1.x to 192.168.55.x, the interloper would be put in that subnet as well.
The bigger issue is with "occasionally." A lot of us have assigned IP addresses to specific devices (for a variety of reasons). Changing the DHCP pool could mean reassigning all of those devices. Not a happy thought.
