Hamstar's avatar
Hamstar
Guide
Mar 16, 2019
How to change the timezone on my Orbi RB50
I noticed the timestamp in my logs is off by -1 hour. I am located in Eastern US timezone and the timestamp is showing as Central US timezone.  Is there a timezone setting somewhere? I have the Orbi ...
  • ekhalil's avatar
    Mar 16, 2019
    Yes, you can set the time zone in the web GUI under >> ADVANCED >> Administration >> NTP Settings
