RebelDad's avatar
Jun 26, 2019
How to change the transmit power on Orbi RBR50?
Is there a way to change the transmit power on Orbi RBR50 other than using telnet?   This should certainly be available in the web interface but I can't find it.   Thanks.
  • CrimpOn's avatar
    Jun 27, 2019
    Advanced Tab->Advanced Settings->Advanced Wireless Settings
