Rmngg
Feb 18, 2019Aspirant
How to change wireless device from 2.4 to 5G or to a closer satellite
- Feb 18, 2019
Some wireless devices do NOT support 5g and will never go there.
If you have a device that is connected to your network and you think it should be joining a satellite that is closer, just try power cycle/rebooting that particular device.
Devices -- under normal conditions -- will choose the band and satellite that is best for them. Sometimes we dont understand why it made those choices, but between the crowded RF spectrum and electromagnetic intereference as well as buoilding materials and RF harmonics, devices pick satellites and bands that dont make sense to us... but it does to them.
Chuck_M
Feb 18, 2019Mentor
- RmnggFeb 18, 2019Aspirant
Great info thanks. I should have mentioed, I had moved the Sattelite units around as I was add a "wall" unit and rearranging other things. Sounds like I should power cycle those devices that I am concerned about and see what happens. One followon question that may be resolved by the Power Cycle, but if not... I have 3 ring "Stick-up Cameras" . 2 connected at 5G, but 1 at 2.4G. If POR does not correct, is there an alternate suggestion?
