orbisteve's avatar
orbisteve
How to configure a new Orbi from a previous setup?
I bought a RBR50 and am moving my existing RBR40 to another location. Is there a way I can transfer my existing RBR40 configuration to the new RBR50 without having to go through the whole setup process all over again? Thanks in advance for any help.
  • FURRYe38's avatar
    No, you'll need to set up from a fresh start.
    • orbisteve's avatar
      orbisteve
      Thanks, and thanks for the quick reply! I guess the new one will go to the location in that case.
      • FURRYe38's avatar
        Make new backup configurations to file for safe keeping.
        Good Luck. :smileywink:
