bkimes777's avatar
bkimes777
How to configure IP address for satellite LAN ports
I have the RBR50 with 2 satellites.  It is in AP mode.  I'd like to change the IP address that the satellite provides when something is plugged into the LAN ports.  I've looked through everything (I ...
  • CrimpOn's avatar
    Apr 03, 2020
    When the Orbi is in Access Point (AP) mode, every device (including the Orbi's) gets an IP address from the upstread router.  That router probably has a web interface where you can access the DHCP settings and define which IP address is given to specific devices by their Media Access Control (MAC) address.
    This is not something that can be done on the Orbi when in AP mode.
