bkimes777
Apr 03, 2020Aspirant
How to configure IP address for satellite LAN ports
I have the RBR50 with 2 satellites. It is in AP mode. I'd like to change the IP address that the satellite provides when something is plugged into the LAN ports. I've looked through everything (I ...
- Apr 03, 2020
When the Orbi is in Access Point (AP) mode, every device (including the Orbi's) gets an IP address from the upstread router. That router probably has a web interface where you can access the DHCP settings and define which IP address is given to specific devices by their Media Access Control (MAC) address.
This is not something that can be done on the Orbi when in AP mode.
CrimpOn
Apr 03, 2020Guru - Experienced User
bkimes777
Thanks for the note! After your information I went and double checked a few things and feel like an idiot -- what is it that they say - measure twice, cut once?
I just saw the wired IP address I got when I connected and assumed it was given from the ORBI .. instead, I forgot I had hardcoded that IP in the laptop instead of allowing DHCP.
Too much time inside from C19, I'm losing my mind!
Thanks -
