Kcobra1's avatar
Kcobra1
Follower
Dec 11, 2020
How to connect 2.4GHZ Devices
I just bought few smart plugs. But they only connect to 2.4 Ghz. How do i add them to my home network as they will not show up in App on my phone for a setup. I have a good coverage in my house so mo...
  • CrimpOn's avatar
    Dec 11, 2020
    Kcobra1 wrote:
    I just bought few smart plugs. But they only connect to 2.4 Ghz. How do i add them to my home network as they will not show up in App on my phone for a setup. I have a good coverage in my house so most of the time phone is on 5Ghz.
    While the smartphone apps for many (most?) Internet of Things (IoT) devices are able to deal with "mesh" WiFi networks, there are some which are poorly written and simply fail to work when the smartphone is connected at 5G. What has worked for many people (including me) is this:
    • Access the Orbi web interface (http://orbilogin.net) using the admin credentials user "admin" and the Orbi router password (not the WiFi password)
    • Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
    • Uncheck the box "Broadcast SSID on 5G Channel"
      This will not affect any devices which are currently attached to the Orbi at 5G.
    • On the smartphone settings, "forget" the Orbi WiFi
    • Search for WiFi networks and select the Orbi WiFi
    • Enter the WiF password and connect
    • At this point, open the IoT app and go through the steps
    • After the device is connected, reverse the steps
      Check the box "Broadcast SSID"
      "Forget Orbi WiFi"
      Search for and connect.
    This sounds like a lot of work, but doesn't take very long.
    p.s. "Poorly written" may seem harsh, but GEEZ.  My TP-Link, Belkin, Eufy, Teckin (and other) smart plugs connected immediately.  I have only had one that required the above steps.  For one plug, I simply ignored the warnings "MUST connect to w.4G" and kept hitting "Continue" until it worked.  "TAKE THAT!", I said.
