jeffjunkyard
Apr 05, 2020Follower
How to connect a wifi device to Orbi RBK22 that only uses 2.4 ghz band
I have the Orbi RBk22 home wifi system i am trying to connect my Treager gril to the wifi through the Traegar app on my phone for remote control of my grill. The grill only uses the 2.4 ghz band but...
tomschmidt
Apr 05, 2020Virtuoso
Try this method which works for most IoT devices that require your smart phone to also be on the 2.4GHz frequency to configure their WiFi.
1. Launch a web browser from a computer or mobile device that is connected to the Orbi network.
2. Enter orbilogin.com or 192.168.1.1 (IP address of your router's LAN port).
3. The login window opens, enter username "admin" and the password that you configured for your router.
4. Click Advanced tab > Advanced Setup > Wireless Settings.
5. Uncheck the box "Broadcast SSID" for the 5GHz frequency and click Apply to save the settings.
6. Confirm that your smartphone is connected to the 2.4GHz frequency. If it is still connected to the 5GHz frequency, then "Forget" the WiFi network for your SSID, then reconnect to it and enter your SSID password. Now your smartphone should be on the 2.4GHz frequency.
7. Try connecting your IoT device to the Orbi network per its setup instructions.
8. If it works, re-enable the broadcast SSID option for the 5GHz frequency.
9. On your smartphone, turn WiFi off and back on again and it should reconnect to the strongest signal.
10. If your smartphone did not reconnect to the 5GHz frequency, then "Forget" the WiFi network again for your SSID, then reconnect to it and enter your SSID password.
