Bovie
Dec 26, 2021Follower
How to connect an external hard drive to my Orbi AC 3000 system
Dec 27, 2021Guru - Experienced User
The Orbi has an usb port but it doesn't have usb hard drive support for them.
You can buy a cheap device like a raspberry pi and setup a nas with it. Or a cheap nas enclosure that supports ethernet connection.
- michaelkenwardDec 27, 2021Guru - Experienced User
Easier said than done.
NAS and "cheaper" don't usually go together. At least, not if you are looking for something in the same price bracket as USB enclosures.
- plemansDec 27, 2021Guru - Experienced User
You can make a raspberry pi work as a nas device :)
- CrimpOnDec 27, 2021Guru - Experienced User
It is really annoying that Netgear continues to release Nighthawk models with USB 3.0 ports for ReadyShare and simply abandoned the effort on the Orbi product. It was clearly part of the "plan" back in 2016 and (as usual) there has never been any statement from Netgear explaining why they didn't follow through.
Buying a Raspberry Pi and setting it up will cost more in time and money than many USB drives cost, plus the effort is not trivial. Plugging in a USB cable is about as non-technical as it gets.
Life is full of disappointments, and using USB drives on Orbi is one of them.
