MarcoBru
Nov 16, 2020Tutor
how to connect Orbi 50 to FTTC
Hello I'm moving my connection from a terminal adapter PPOE to a FTTC fiber. SO I need a external modem. How can I setup everything in order to keep the Orbi as DHCP server? thanx
- Nov 16, 2020
First contact your ISP to see what is required by them regarding any modems, etc.
For modems with a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Nov 16, 2020Guru - Experienced User
Couple of options,
