Joel1949
Sep 21, 2022Aspirant
How to connect Orbi RBR40 to ATT fiberoptic
I just had ATT fiberoptic installed. It came with a router/modem all in one. I have tried everything to get the Orbi router to connect to the internet through the ATT unit, but it stays purple and “ca...
ekhalil
Sep 21, 2022Master
What is the make and model of the ATT modem/router?
If the ATT unit has router functionality then this can explain the issues that you see, in that case you need either to set the ATT router to bridge/passthrough mode or set Orbi in AP mode.
- Joel1949Sep 22, 2022Aspirant
Model BGW320-505
- ekhalilSep 22, 2022Master
Yes, this is a router. Please set Orbi in AP mode. Follow these steps please:
- Use any browser on a computer attached to Orbi
- Go to orbilogin.com and login using the username admin and the password that you choose during the setup.
- Go to >> ADVANCED >> Advanced Setup>> Router / AP Mode and select AP Mode.
