fchahua
May 19, 2020Follower
How to connect to 2.4GHz devices to the orbi
I have bought a HeimVision 1080P Security Camera HM203 UG WiFi Home Indoor Camera with smartphone app which only connects to a 2.4ghz but it's connecting to my ORBI which it should connect to both 2....
May 19, 2020Guru - Experienced User
Netgear provides a simple mechanism to accomplish this:
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.
Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
EGLink2
Jul 30, 2022Aspirant
When I logged into the Orbi web interface (http://orbilogin.net), there were no tabs to navigate to! There wasn't an Advanced Tab, Advanced Settings, or Wireless Settings. What internet browser did you use? I tried both Firefox and Safari, but neither has tabs on the orbilogin site.
Thank you for clarification.
