fchahua
May 19, 2020Follower
How to connect to 2.4GHz devices to the orbi
I have bought a HeimVision 1080P Security Camera HM203 UG WiFi Home Indoor Camera with smartphone app which only connects to a 2.4ghz but it's connecting to my ORBI which it should connect to both 2....
ZipFunk
Mar 09, 2024Aspirant
FURRYe38 If I click on your link I go to what looks like Netgear's product page. If I type 192.168.1.1 I go to my router settings.
I click on the advanced tab but I don't see any checkbox that says Broadcast on SSID to uncheck
CrimpOn
Mar 09, 2024Guru - Experienced User
Netgear provided a feature to enable/disable broadcasting the WiFi SSID on the original Orbi models. That feature was dropped when the newer products were introduced. (This is one of the pitfalls of trying to continue a discussion from 2020 rather than begin a new discussion.)
The vast majority of Internet of Things (IoT) devices connect to Orbi WiFi systems as easily as they do to any other mesh WiFi. Unfortunately, there are some products which have poorly written application software which makes the original setup difficult. (Once the device has been connected to the customer WiFi system, this problem disappears.)
I suggest beginning a new conversation. Please include:
- Which specific Orbi system is being used. (From the product label on the bottom of the router.)
- Which specific device is being connected to WiFi.
- A link to the vendor instructions for connecting the device to WiFi.
- A description of where in the process the failure occurs.
