JesseJG
Jul 05, 2019Aspirant
How to connect two Orbi (RBK44) routers to cover large area
I need Wi-Fi coverage over a large area (Home, Pool, Shed, & Pier). I have 200 feet outside space between my house a shed and another 300 feet to the end of my pier. I would like to feed the shed and...
CrimpOn
Jul 07, 2019Guru - Experienced User
JesseJG wrote:So questions are: Can two Orbi routers be connected to my Verizon FiOS Router? What setup changes (Orbi router or Verizon FiOS Router) do I need to make?
Yes, as many Orbi routers can be connected to FIOS as there are ethernet ports (or, if a switch is connected to FIOS, as many as there are ports on the switch). In AP mode, every device connected gets an IP address from the FIOS. They will all be separate WiFi networks, so the "mesh" benefits will be lost.
JesseJG
Jul 07, 2019Aspirant
So, the end result would be two separate mesh network, correct?
With the limitation of the 3 satellites and the area I need to cover, I don’t believe I have any other option.
- CrimpOnJul 07, 2019Guru - Experienced User
JesseJG wrote:With the limitation of the 3 satellites and the area I need to cover, I don’t believe I have any other option.
Just to be clear, there is no "3 satellite limitation" with Orbi. Some users report having six or more satellites attached to one router.
The problem is that individual statellites can be difficult to purchase, or actually be more expensive than purchasing another "package" deal.
I just searched on Amazon, and the only RBS40 units are "used" at $171. I tried the Netgear web site, and every retailer they list shows the RBS40 as "unavailable."
Any Orbi satellite will work with any Orbi router, although it obviously would be unusual to add a "50" model satellite to a base unit that doesn't support the higher speed backhaul.
- JesseJGJul 07, 2019AspirantThe no limit on satellites is very interesting. I wasn’t aware of that. Orbi customer support indicated that limit and agreed to my plan of two routers.
Thank you for this additional perspective.- CrimpOnJul 07, 2019Guru - Experienced User
The largest number of satellites that I have seen recently is six. Thevidpro reports having an RBR20 with five satellites in his warehouse. People seem to "run out of house" by the time they have a router and 5-6 satellites deployed. Usage and bandwidth are the critical factors. The RBR40, for example, is an "AC2200" router that has six antennas. Here's a look at the insides: https://fccid.io/PY316400362/Internal-Photos/Internal-Photos-rev-2-pdf-3301776
The 866mb backhaul bandwidth is shared with all satellites that are connected. Distance can reduce the effective bandwidth. (866 is the theoretical maximum). When satellites are "daisy chained", then the backhaul radio in the middle satellite is busy talking to the router and also to the farther satellite.
If all the farthest satellites are doing is "Internet of Things" (IoT) stuff, like turning lights on and off,,email, and web browsing, the system can probably support 100's of devices. If people decide to simultaneously stream 4K video on 3-4 satellites at a time, I would not be surprised if performance was disappointing.
