MasterFuba
Jul 18, 2022Follower
How to deactivate 5GHz or get a different SSID for it?
Hi all Netgear users out there, I have Netgear routers since the very beginning of WLAN and most of the devices were just great. With Orbi its quite different - the poeple who defined the key pa...
Jul 18, 2022Guru - Experienced User
Did you turn OFF the RBS then lower the transmit power on the RBR to 25% then try to connect your device?
If you have a 50 series Orbi you might try disabling the SSID broadcast.
FYI:
