slipsibm's avatar
slipsibm
How to disable / deactivate Armor on RBR50?
I upgraded my RBR50 router to 2.3.1.32 and then 2.3.1.44. Since the upgrade to 2.3.1.32, I have been experiencing frequent loss of Internet access. Before I downgrade back to 2.2.1.210, I wanted to try and deactivate Armor but can't find an option to do this to see if that is the problem. How do Disable Armor?
Anyone else losing Internet access?
  • What is the Mfr and model# of the ISP modem the NG router is connected too?
    I would factory reset and setup from scratch if you haven't already. You can try not enabling Armor at this point, do a back up configuration to file, then give it one more try to see if the reset fixes anything...if not, re-apply the back up config from file.
  • I would also reboot ALL equipment starting at your modem and work my way down to see if that makes any difference.
    Make sure you leave power off for a few minutes and remove any batteries before cranking back up.
