Iamnobody
Mar 15, 2017Aspirant
How to disable 2.4G in my Orbi
Hi, I have a Orbi, but how can I disable the 2.4G, I don't want to use it. Otherwise, What is the connection between Router and Satellite? Is it 5Ghz?
schumaku
Mar 15, 2017Guru - Experienced User
Iamnobody wrote:What is the connection between Router and Satellite? Is it 5Ghz?
The Orbi wireless distribution mesh based on dedicated a AC1750 5 GHz band radio, independant of the 5 GHz access point radio.
If there is no control to enable/disable the 2.4 GHz radios ...
-Kurt
- IamnobodyMar 15, 2017Aspirant
-Kurt
Hello Sir,
If my understanding is right, that means I won't get link rate over 866Mbps in 11ac even my client is 3x3, because the backhaul used it, right?
I can't find any button to disable 2.4GHz on GUI, there is only a button to hide 2.4G SSID boardcast, however, Orbi only allows one SSID for 2.4G & 5G, why is no way to enable/disable 2.4GHz.
- schumakuMar 15, 2017Guru - Experienced User
Iamnobody wrote:If my understanding is right, that means I won't get link rate over 866Mbps in 11ac even my client is 3x3, because the backhaul used it, right?
Correct. FIts to my observations, several test reports, and last but not least Netgear KB: At what speed and bandwidth can my Orbi system transmit data?
The math and the marketing aspect of "AC3000" was discussed before, ie. here https://community.netgear.com/t5/Orbi/Orbi-AC3000-or-really-AC1266/m-p/1172945#M1150
Answered above by TomMac Have no Orbi accessible as of writing..
-Kurt
