RossBev
Dec 27, 2017Follower
HOW TO DISABLE 5G TEMPORARILY ON ORBI ROUTER
HELLO, I own an Orbi system and recently obtained a Personal Weather station that does direct uploads to various weather sites online. The weather station will only connect to Wi-Fi via a 2.4GHZ sys...
guzzijason
May 08, 2018Apprentice
You're missing the closing paren after "wl5g_NORMAL_AP", before the semicolon.
Mike734
Jun 10, 2018Star
I'm trying this. When the script runs, should it run by repeting the line "down xx"?
- guzzijasonJun 10, 2018Apprentice
I think that's right (I can't test it at the moment).
The script shuts down the interface, but if memory serves, there is a sort of watchdog that automatically brings the interface back up after a while, which is why the "ip set link down ..." portion is looped repeatedly, for 60 seconds in the example I gave.
