RossBev
Dec 27, 2017Follower
HOW TO DISABLE 5G TEMPORARILY ON ORBI ROUTER
HELLO, I own an Orbi system and recently obtained a Personal Weather station that does direct uploads to various weather sites online. The weather station will only connect to Wi-Fi via a 2.4GHZ sys...
guzzijason
Dec 27, 2017Apprentice
There seem to be a number of people having the same sort of issue lately. I believe the older firmware let you power off the radios, but the recent firmware does not. You can manually disable a specific interface on the command line, but there is an autmated watchdog process that will bring it back up again, usually within seconds.
I did work out a hacky way of temporarily downing the 5 GHz interface that might work for you:
- Shut off your satellites (otherwise, you need to repeat the following steps on all of them, in addition to router)
- Enable telnet on the router (from the /debug.htm page of the web interface)
- telnet to router
- After loggin in, run the following comand script on the command line (yes, 1 big line):
seconds=60; x=0; while [ $x -lt $seconds ]; do ip link set down dev $(config get wl5g_NORMAL_AP); x=$(( x + 1 )); echo "down $x"; sleep 1; done
This command will determine the interface for the primary 5 GHz, and shut it down for 60 seconds. If you want to change the amount of time that the interface stays down, simply change the "seconds=60" part of the script to whatever you want.
This doesn't make any permanent config changes, so if worse comes to worse, simply reboot the router and you should be right back to where you were.
Good luck!
Kmaan
Aug 29, 2018Aspirant
Great solution, Kudos! I have a RBK50 and two RBW30 connected together to form a mesh system. Due to the evergreen wifi dropouts we've been hearing for a long time, I decided to separate the 2.4 GHz and 5 GHz (using telnet) . I still couldn't figure out how to keep separate passwords for the two speeds? Anyone out there had any luck to do this using telnet?
Appreciate your feedbacks/experiences!!!
- bebeblaOct 03, 2018Tutor
Can somebody please give me a tone down version for somebody who is not that saavy about commands etc. I see the instruction, but can't even figure out how to get to telnet and run the command. I am trying to connect Deebot device, and need to get my Orbi to provide 2.4 only. Please help
