RossBev
Dec 27, 2017Follower
HOW TO DISABLE 5G TEMPORARILY ON ORBI ROUTER
HELLO, I own an Orbi system and recently obtained a Personal Weather station that does direct uploads to various weather sites online. The weather station will only connect to Wi-Fi via a 2.4GHZ sys...
ajlabora
Nov 04, 2018Aspirant
Go to the advanced tab on the web settings for your router and on the left you will see towards the bottom a line that reads advanced setup. Click on the + singn and then on the wireless settings. From there all should be self explanatory. When you are done configuring your 2.4 device come back and renable all the way it was before.
You are now back where you started.
Hope this helps.
