RossBev
Dec 27, 2017Follower
HOW TO DISABLE 5G TEMPORARILY ON ORBI ROUTER
HELLO, I own an Orbi system and recently obtained a Personal Weather station that does direct uploads to various weather sites online. The weather station will only connect to Wi-Fi via a 2.4GHZ sys...
mrpthompson
Jan 30, 2020Aspirant
Great solution.
guzzijason2
Jan 30, 2020Guide
Turning of the 5GHz SSID broadcast DOES NOT turn off the 5GHz radio! Disabling SSID broadcast is rather pointless - all it does it stop the router from announcing itsellf, but it DOES NOT prevent clients from still connecting to 5GHz. Some people do this for security (but its a placebo... no real security benefit from turning off SSID broadcast).
The ONLY method that I'm aware of to truly disable the 5GHz radio is the procedure I documented in post #2 on this thread. Once the 5GHz radio is disabled, your phone will have zero choice but to connect via 2.4GHz.
- FURRYe38Jan 30, 2020Guru - Experienced User
Devices remember the last wifi connection in there profiles. Thus will connect to the 5Ghz radio, even though the SSID has been hidden or disabled. We know this, however to get client side HW to connect to the 2.4Ghz radio, users have to tell the phone or pad to forget the current wifi network, then disable the wifi radio on the device then re-enable the wifi radio, then have the device re-connect to the SSID which will be only seen as the 2.4Ghz wifi radio. Input the password and the phone or pad will conect to the 2.4Ghz radios. This does work.
- LightSportJan 31, 2020Aspirant
THIS WORKED! thanks
