RossBev
Dec 27, 2017Follower
HOW TO DISABLE 5G TEMPORARILY ON ORBI ROUTER
HELLO, I own an Orbi system and recently obtained a Personal Weather station that does direct uploads to various weather sites online. The weather station will only connect to Wi-Fi via a 2.4GHZ sys...
FirstKen
Feb 04, 2020Star
I am not so inclined. Re-read my previous posts, I have been and still am interested in only one thing, and that is getting the LaCrosse device working properly with the Orbi. I'm not interested in any involvement regarding software/firmware changes or fixes, and I am also not interested in the 'whys' or 'why nots'. As I stated, I have only one goal in mind and that is to get a device that is suppose to be compatible with the Orbi to work properly with the Orbi. It's that simple. Again, if you will read my previous post, you will see that LaCrosse has offered what should be a solution fo this issue. I'll know when I receive the decice.
Cheers.
Feb 04, 2020Guru - Experienced User
Good Luck.
- CSAUSTRALIAFeb 15, 2020Aspirant
.I hope this helps someone. We had the same problem linking security cameras to the Orbi. Ended up firing up an older router that allows 5g to be disabled. Switched the Orbi OFF. Gave the old wifi with only 2.4g the same password as the Orbi. Connected the cameras. Switched the old router off and reconnected the Orbi. All works fine.
- FURRYe38Feb 17, 2020Guru - Experienced User
You can do this as well on the RBR:
CSAUSTRALIA wrote:.I hope this helps someone. We had the same problem linking security cameras to the Orbi. Ended up firing up an older router that allows 5g to be disabled. Switched the Orbi OFF. Gave the old wifi with only 2.4g the same password as the Orbi. Connected the cameras. Switched the old router off and reconnected the Orbi. All works fine.
- UltradogMar 07, 2020TutorCSAUSTRALIA Great idea, thanks! Old router worked like a charm. I have a LaCrosse weather station and 3 Chamberlain garage door openers that are super fussy about the network. all are happy now!
