Anonymous's avatar
Anonymous
Nov 17, 2019
How to disable 5GHz side of Orbi network
I just bought a Wemo Mini WiFi plug and Smart Dimmer switch that only use 2.4Ghz.   Is there an easy way to temporarily disable the 5Ghz network so I can associate the WIFi plug with Apple HomeKit?...
