YogaMan
Mar 07, 2019Follower
How to disable all WiFi Bluetooth Air Signals on Orbi Voice w/ Amazon Alexa? AC3000 (RBK50V)
Can I disable all WiFi / Bluetooth / Any Air Signals and just use direct connect Ethernet? Will I loose any features? Thank You
- Mar 19, 2019
seems it was not my Orbi voice after all
followed instructions here (https://community.netgear.com/t5/Orbi/How-to-set-a-separate-SSID-for-the-5-GHz-network-on-your-Orbi/td-p/1396594) and named my 2.4 & 5Ghz networks.
So far it seems to be working much better
ekhalil
Mar 10, 2019Master
YogaMan wrote:
Can I disable all WiFi / Bluetooth / Any Air Signals and just use direct connect Ethernet? ......
Not using normal configuration but you can disable wifi interfaces on the node using telnet commands.
YogaMan wrote:
....... Will I loose any features?
You will just loose the wireless connectivity to the Satellite so it will not be part of your mesh network!
- fverbistMar 17, 2019Aspirant
Do you have a link to any documentation on that?
I have a feeling that my Orbi Voice is messing up with my wifi setup...
Tried to put it on ethernet to take backhaul out of the equation, still poor wifi performance
Turned it off and my Orbi setup is cool again.
- fverbistMar 19, 2019Aspirant
