gman88
Apr 03, 2021Tutor
How to disable AP Isolation RBR730 ?
I would like to disable AP Isolation. As per the image below, AP Isolation is set to "on" for both Guest and Main networks (see attached image). I would like to disable it for either or both networ...
Apr 03, 2021Guru - Experienced User
Please visit and post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
