pstoric83
Aug 04, 2017Guide
How to disable auto-update
I prefer to update manually, is there a way to turn that feature off?
- cyberprashantLuminarySo far, the Only reliable way to block the upgrade is page 5 of this thread (telnet method) - see link below. IT seems a little overwhelming but its not bad. Takes all but a few minutes. Plus apply the same block to the extra parameter (orbi_auto_upg) - anything that looks like an upgrade parameter in the list. And you have to be fast in doing this or the router will still auto-upgrade (to prevent this I recommend downloading everything u need first and then disconnecting your cable or DSL line while doing this so it doesnt auto-upgrade in the process.
it still updates itself automatically ... this is ridiculous !!
- aazVirtuoso
Vengeance wrote:it still updates itself automatically ... this is ridiculous !!
Not ridiculous at all for a modern IOT device. All cloud managed devices do this for obvious reasons. Being in the IT field myself I applaud this as It prevents people from doing stupid things like never updating their firmware which is guaranteed to have security holes thereby leaving them exposed to malicious actors on the internet.
- JustMakeItWorkApprentice
That's great until you have clearly untested firware breaking devices all over creation. Since Netgear has chosen to force its updates and break the Internet for many, they're responsible for anything that happens while its down.
