rix0rrr
May 01, 2018Star
How to disable auto upgrade?
As mentioned in this topic: https://community.netgear.com/t5/Orbi/Drops-network-every-30-seconds-for-5-seconds/m-p/1505649/highlight/true#M23564
I still keep having period 5-second complete net...
May 03, 2018Guru - Experienced User
Did you try setting up a block on FTP port 21 to 191.168.1.1?
Also add those URLs to block?
- rix0rrrMay 03, 2018Star
I would if I could, but my Orbi is in AP mode which disables all further configuration and my home router's filtering capabilities are laughable.
So kneecapping the Orbi's ability to upgrade itself seems to be my best bet.
- FURRYe38May 03, 2018Guru - Experienced User
I presume this would or in Router mode. Ya AP mode disable all non required features for AP mode.
Was told it works in router mode.
Let us know if your solution works for you in AP mode.
- FURRYe38May 22, 2018Guru - Experienced User
How about blocking FTP to the IP address of the Orbi while in AP mode on your main host router?
