rix0rrr
May 01, 2018Star
How to disable auto upgrade?
As mentioned in this topic: https://community.netgear.com/t5/Orbi/Drops-network-every-30-seconds-for-5-seconds/m-p/1505649/highlight/true#M23564
I still keep having period 5-second complete net...
rix0rrr
May 03, 2018Star
I would if I could, but my Orbi is in AP mode which disables all further configuration and my home router's filtering capabilities are laughable.
So kneecapping the Orbi's ability to upgrade itself seems to be my best bet.
May 03, 2018Guru - Experienced User
I presume this would or in Router mode. Ya AP mode disable all non required features for AP mode.
Was told it works in router mode.
Let us know if your solution works for you in AP mode.
