X1Zero
Feb 01, 2021Guide
How to disable automatic firmware updates?
Where is the option to disable firmware updates? There seems to be no option in the Orbi App and no option on the Orbilogin web browser log in page either. I’ve been (happily) on the same firmware ...
X1Zero
Aug 31, 2021Guide
Looks like it happened again. I have the RBK23 modem/satellites and just a few hours ago everything was force updated to 2.7.3.22.
Prior to this, I was happily on 2.5.1.16 for over a year.
The part I don't understand is how this happened, especially since I've manually disabled all automatic updates in the router using the Telnet method. This is where you log into the router and disable the below configurations.
orbi_auto_upgrade=1
auto_check_for_upgrade=1
auto_update=1
Anyway, been running fine with all the firmware updates being bypassed for the past year except now with 2.7.3.22.
Has this occurred to anyone? How did the router bypass the disabled update configurations?!
- FURRYe38Aug 31, 2021Guru - Experienced User
I presume NG puts in code to allow updates regardless on whats set ON the RBR. I tried this with my 8 series Orbi and found the only way to block auto FW updates is to have a upstream router in place that blocks:
http.fw.updates1.netgear.com and updates1.netgear.com
- mbreksopNov 01, 2021Star
But then you daisy chain two routers and ISP Modem, is that right ?
I still don't get it, my NG forced updates to their customer, it's one way to ruin their great products.
- FURRYe38Nov 01, 2021Guru - Experienced User
Yes. You can daisy chain two routers and block FW Updates with the upstream router from the Orbi router.
Yes, it happens to all of us....
I even try to block the DNS to no avail
- lookatyouNov 16, 2021AspirantNetgear reserves the right to push firmware that deemed needed to fix security holes regardless of what telnet settings you have chosen.
