JAP66
Jan 08, 2020Aspirant
How to disable google assistant from a netgear account
I have recently enabled the use of my google assistant to interact with and control my Orbi network using only my voice. However, I want to disable such feature from my google assistant without s...
- Jan 08, 2020
(Caveat: I have not enabled Google Assistant, and probably never will)
Searching the forum for "Google Assistant" brought up instructions for how to link it to the Orbi:
A key step appears to be entering the Netgear account name and password. Seems to me that if you change the password, then Google Assistant will no longer be able to access the Orbi. If you try this, please report if it worked as expected (or not).
CrimpOn
Jan 08, 2020Guru - Experienced User
- JAP66Jan 08, 2020Aspirant
It worked like a charm...!!!
Thanks so much for your help!
