tompkinss2
Jun 09, 2017Aspirant
How to disable or Access Control only LAN ports on Orbi Satalite
Can anyone tell me if it is possible to disable the LAN ports on a Satalite or even better to enable Access Control block, manual accept connections on Satalite LAN ports? I have a Satalite that peo...
gfrey
Jun 09, 2017Apprentice
Advanced --> Security --> Access Control is your only option then use Block All New Devices
- tompkinss2Jun 09, 2017Aspirant
But that blocks wireless and wired ports, I just want to block wired.
