tompkinss2's avatar
tompkinss2
How to disable or Access Control only LAN ports on Orbi Satalite
Can anyone tell me if it is possible to disable the LAN ports on a Satalite or even better to enable Access Control block, manual accept connections on Satalite LAN ports?  I have a Satalite that peo...
