yata001
Dec 16, 2018Star
How to disable WiFi on the Orbi Router or Satellite
Enable on telnet on the router or satellite
For the router, go to http://192.168.1.1/debug.htm
For a statellite, log into the router, copy the IP address of the satellite, and go to http://<sat...
yata001
Jan 02, 2019Star
Thanks for the correction.
The settings work on the latest firmware, V2.2.1.210. Also, you have to apply the settings to every router and satellite if you want to disable 2.4GHz entirely. To check that the settings were applied, run the command "config get endis_wl_radio" and make sure it returns 0. Also run "iwconfig $(config get wl2g_NORMAL_AP)" and verify that Access Point is Not-Associated.
If you're willing to try something untested, it appears that the entire 2.4 and 5GHz bands can be disable from the web interface. You have to log into the router and navigate to Advanced -> Advanced Settings -> Wireless Settings. Then open the web console in firefox (Developer Tools then Console for Chrome) and enter the following and press return:
document.getElementById("formframe").contentWindow.document.querySelectorAll("[style='display:none']").forEach(i => i.removeAttribute("style"))
This should show all the hidden elements including the "Enable Wireless Router Radio" checkboxes for 2.4 and 5GHz. You can uncheck and press Apply.
It seems to conflict with the first procedure so I haven't really tested to see if it works.
Barney67
Jan 02, 2019Aspirant
Hi,
Ok can confirm this is NOT disabling the 2.4 Wifi on the router.
I do the following:
config set endis_wl_radio=0
config get endis_wl_radio (Returns 0)
ifconfig $(config get wl2g_NORMAL_AP) down
config commit
reboot
config get endis_wl_radio (Returns 1 after reboot)
I do have different SSID for 2.4 and 5GHz Networks if this makes a difference.
I have the satellite turned off during the test.
- Barney67Jan 02, 2019Aspirant
I should add I get the same result using the webpage
The 2.4GHz radio does turn off, but comes back after a power restart. Same result if i use the checkbox on the web interface. Thanks for your help.
- FURRYe38Jan 02, 2019Guru - Experienced User
Sounds like this modification is not supported in the FW and is only temporary and doesn't persist past a reboot.
- ekhalilJan 11, 2019Master
Barney67 wrote:
Hi,
I do the following:
config commit
reboot
I tested this procedure now. The command "ifconfig $(config get wl2g_NORMAL_AP) down" does not work for some reason. Instead follow the following procedure:
- For 2.4Ghz band use
- config set endis_wl_radio=0
- config get wl2g_NORMAL_AP --> Get the prontout (should be ath0)
- ifconfig ath0 down --> Or use the output from command in point 2 above
- For the 5Ghz band use
- config set endis_wla_radio=0
- config get wl5g_NORMAL_AP --> Get the prontout (should be ath1)
- ifconfig ath1 down --> Or use the output from command in point 2 above
- For the guest 2.4Ghz band use
- config set wlg1_endis_guestNet=0
- For the guest 5Ghz band use
- config set wla1_endis_guestNet=0
- config get wl5g_GUEST_AP --> Get the prontout (should be ath11)
- ifconfig ath11 down --> Or use the output from command in point 2 above
- troytemplinMar 09, 2019Aspirant
This worked perfectly but if I want to turn it back on what are the commands?
- ekhalilMar 09, 2019Master
- To disable: For 2.4Ghz band use
- To enable back: For 2.4Ghz band use
- config set endis_wla_2nd_radio=1
- config set wl2g_NORMAL_AP=ath0
- ifconfig ath0 up
- To diable: For the 5Ghz band use
- To enable back: For 5Ghz band use
- config set wl5g_NORMAL_AP=ath1
- ifconfig ath1 up
- To disable: For the guest 2.4Ghz band use
- config get wl2g_GUEST_AP --> Get the prontout (should be ath02)
- ifconfig ath02 down --> Or use the output from command in point 2 above
- To enable back: For the guest 2.4Ghz band use
- config set wl2g_GUEST_AP=ath02
- ifconfig ath02 up
- To disable: For the guest 5Ghz band use
- To enable back: For the guest 5Ghz band use
- config set wl5g_GUEST_AP=ath11
- ifconfig ath11 up
