yata001
Dec 16, 2018Star
How to disable WiFi on the Orbi Router or Satellite
Enable on telnet on the router or satellite
For the router, go to http://192.168.1.1/debug.htm
For a statellite, log into the router, copy the IP address of the satellite, and go to http://<sat...
icalks
May 12, 2019Tutor
This is insane. Disabling the 2.4GHz or 5GHz channel should be as easy as going to wifi settings and doing so. Is anyone from Orbi/Netgear monitoring this thread? Please fix this interface shortcoming.
May 13, 2019Guru - Experienced User
You can't disable the WiFi SSID broadcast only. Disabling of either radio is not officially supported by any other means. This is not a bug. Orbi needs wifi running so the RBS and any connected devices have wifi signal. How it's designed. If you need to disable wifi radios on a schedule, find something else that supports this.
- rootardJul 09, 2019Aspirant
Hello
I want to switch off the router at night. As there's no such option in the interface I've made a series of attempts using ifconfig + crontab.
I've listed all interfaces on my RBR20, there are plenty more including NetGear_Hidden: sync channels?
wl2g_NORMAL_AP is ath0 and wl5g_NORMAL_AP is ath2
root@RBR20:~/mnt/circle/localinit# iwconfig
ath02 IEEE 802.11b ESSID:"NETGEAR-Guest"
Mode:Master Frequency:2.472 GHz Access Point: Not-Associatedath12 IEEE 802.11ac ESSID:"NETGEAR-Guest"
Mode:Master Frequency:5.54 GHz Access Point: Not-Associatedath0 IEEE 802.11ng ESSID:"MYSSID"
Mode:Master Frequency:2.472 GHz Access Point: XX:XX:XX:XX:XX:XXath1 IEEE 802.11ac ESSID:"MYSSID"
Mode:Master Frequency:5.54 GHz Access Point: XX:XX:XX:XX:XX:XXath2 IEEE 802.11ac ESSID:"MYSSID"
Mode:Master Frequency:5.18 GHz Access Point: XX:XX:XX:XX:XX:XXath01 IEEE 802.11ng ESSID:"NETGEAR_ORBI_hidden76"
Mode:Master Frequency:2.472 GHz Access Point: XX:XX:XX:XX:XX:XXath11 IEEE 802.11ac ESSID:"NETGEAR_ORBI_hidden76"
Mode:Master Frequency:5.54 GHz Access Point: XX:XX:XX:XX:XX:XXath21 IEEE 802.11ac ESSID:"NETGEAR-Guest"
Mode:Master Frequency:5.18 GHz Access Point: Not-AssociatedWhen I switch off the satellite then ifconfig down as above I can still see my SSID and the attached devices keep on working !
Worse, after a couple of seconds the APs move back from Not-Associated to their original ON state
iwconfig ath2 power off does'nt work either...
Netgear Please fix this !
Model: RBR20|Orbi AC2200 Tri-band WiFi Router- CrimpOnJul 09, 2019Guru - Experienced User
rootard wrote:I want to switch off the router at night. As there's no such option in the interface I've made a series of attempts using ifconfig + crontab.
Does "switch off the router" mean or "turn off the WiFi but leave wired devices working normally"? Like any other electronic device, the Orbi router can be powered off a timer or even a switched electrical outlet.
