yata001
Dec 16, 2018Star
How to disable WiFi on the Orbi Router or Satellite
Enable on telnet on the router or satellite
For the router, go to http://192.168.1.1/debug.htm
For a statellite, log into the router, copy the IP address of the satellite, and go to http://<sat...
May 13, 2019Guru - Experienced User
You can't disable the WiFi SSID broadcast only. Disabling of either radio is not officially supported by any other means. This is not a bug. Orbi needs wifi running so the RBS and any connected devices have wifi signal. How it's designed. If you need to disable wifi radios on a schedule, find something else that supports this.
icalks wrote:
This is insane. Disabling the 2.4GHz or 5GHz channel should be as easy as going to wifi settings and doing so. Is anyone from Orbi/Netgear monitoring this thread? Please fix this interface shortcoming.
rootard
Jul 09, 2019Aspirant
Hello
I want to switch off the router at night. As there's no such option in the interface I've made a series of attempts using ifconfig + crontab.
I've listed all interfaces on my RBR20, there are plenty more including NetGear_Hidden: sync channels?
wl2g_NORMAL_AP is ath0 and wl5g_NORMAL_AP is ath2
root@RBR20:~/mnt/circle/localinit# iwconfig
ath02 IEEE 802.11b ESSID:"NETGEAR-Guest"
Mode:Master Frequency:2.472 GHz Access Point: Not-Associated
ath12 IEEE 802.11ac ESSID:"NETGEAR-Guest"
Mode:Master Frequency:5.54 GHz Access Point: Not-Associated
ath0 IEEE 802.11ng ESSID:"MYSSID"
Mode:Master Frequency:2.472 GHz Access Point: XX:XX:XX:XX:XX:XX
ath1 IEEE 802.11ac ESSID:"MYSSID"
Mode:Master Frequency:5.54 GHz Access Point: XX:XX:XX:XX:XX:XX
ath2 IEEE 802.11ac ESSID:"MYSSID"
Mode:Master Frequency:5.18 GHz Access Point: XX:XX:XX:XX:XX:XX
ath01 IEEE 802.11ng ESSID:"NETGEAR_ORBI_hidden76"
ath11 IEEE 802.11ac ESSID:"NETGEAR_ORBI_hidden76"
ath21 IEEE 802.11ac ESSID:"NETGEAR-Guest"
Mode:Master Frequency:5.18 GHz Access Point: Not-Associated
When I switch off the satellite then ifconfig down as above I can still see my SSID and the attached devices keep on working !
Worse, after a couple of seconds the APs move back from Not-Associated to their original ON state
iwconfig ath2 power off does'nt work either...
Netgear Please fix this !
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
