WiredWorker
Aug 02, 2018Initiate
How to disable wireless isolation ORBI
Hi,
I have a RBR50 with two satelites. A few weeks ago I bought a Homepod from apple but I can`t control my room by using siri. Everything is set up, and it works from my iphone but nut with m...
DarrenM
Aug 03, 2018Sr. NETGEAR Moderator
There is no wireless isolation on the main network but there is on the guest network.
DarrenM
WiredWorker
Aug 04, 2018Initiate
But why does my Homepod not work with Siri? Are other Orbi users having the same problem? I think this is a network problem.
