mtschirret
Mar 22, 2018Aspirant
How to Enable Access to Devices with Orbi Setup as an AP Behind AT&T BGW210
Hi all--first post. i have an Orbi RBR50 setup as an access point behind my AT&T Gigapower BGW210 combo router/modem. I have both radios turned off on the AT&T, and the network works great connecting...
mtschirret
Mar 23, 2018Aspirant
Thank you very much. I hate to ask, but how do I set up an IP address reservation that the Orbi router gets from the ISP modem on the modem, then input this IP address into the modem's DMZ? I have a setting for "Cascaded router", which is set to "on", and I input the Orbi's IP address. It is also asking for the Network Address that defines the range of IP addresses available to clients of the cascaded router. The subnet mask is filled in. Am I in the right place? If so, what should I use for the network address?
Again, my thanks.
Mar 23, 2018Guru - Experienced User
The IP address reservation is done ON the modem, not the Orbi router. Set a IP address reservation that the modem gives to the Orbi router ON the modem. You'll need to log into the modems web page and do this here. Along with using the DMZ for this IP address.
- mtschirretMar 23, 2018Aspirant
That is what I am doing on the AT&T router, but I don't see anything about "DMZ". I found the Orbi's IP address and used that; but do not know what to assign for the network address...
- FURRYe38Mar 23, 2018Guru - Experienced User
You'll need to ask your ISP about DMZ on this model modem. See if you can find any user manual for it and see if there is anything about DMZ. DMZ is usually found under or near Firewall settings if this modem has any such features.
Network address assign as the IP address reservation for the Orbi.
We don't know the lay out of the ISP modem so features and locations will be different. I would contact the ISP and have them help you with this modem. They should know the lay out and how to get this configured.
