axemolt's avatar
axemolt
How to enable DNS over TCP on Orbi
Certain domans lookups that return with a large list of responses failing currently with:
;; Truncated, retrying in TCP mode.
From what I understood, this is because the response too large for UDP and tries to use TCP which gets a "connection refused".
I don't see an router setting to enable DNS over TCP.  Has anyone else experienced this and/or have any suggestions?
    • axemolt's avatar
      axemolt
      I saw this on the my computer (mac), when I was doing an nslookup command.  My browser wouldn't load https://travel.state.gov, so I started troubleshooting.
      ➜ ~ nslookup travel.state.gov
      ;; Connection to <orbi_ip>#53(<orbi_ip>) for travel.state.gov failed: connection refused.
      I confirmed that tcp port 53 is not open on the Orbi:
      ➜ ~ nc -vzu <orbi_ip> 53
      Connection to <orbi_ip> port 53 [udp/domain] succeeded!
      ➜ ~ nc -vz <orbi_ip> 53
      nc: connectx to <orbi_ip> port 53 (tcp) failed: Connection refused
      However, today that nslookup command is working and the browser is loading the page fine.
      • FURRYe38's avatar
  • FURRYe38's avatar
