sam_reitich's avatar
Jun 03, 2019
How to enable FTP Port 21
I am trying to port forward a server using my public ip, but it doesn't work. Using a local host works, but when I try to scan my public ip, it says:
"99.51.65.59 isn't responding on port 21 (ftp)."
I couldn't find how to fix this.
Thanks
  • CrimpOn's avatar
    CrimpOn
    So, you used the Advanced tab on the Orbi web interface, selected Advanced Setup->Port Forwarding, and then entered the IP address of the FTP server on your internal network.  Correct?
      • CrimpOn's avatar
        CrimpOn
        Sorry, I neglected to ask about how the Orbi is connected.  Sometimes the internet modem is actually a "modem/router", which results in what people call a "double NAT".  The Orbi may have forwarded port 21, but the modem/router which is in front of the Orbi may not have.
        What happens when you do a trace route to 8.8.8.8?
        i.e. open a Windows command window and type "tracert 8.8.8.8"?
        The first line should be the Orbi itself, usually 192.168.1.1  The second line should be a "public" IP address, that is NOT a "192.168" or a "10.x"
  • FURRYe38's avatar
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
