sam_reitich
Jun 03, 2019Tutor
How to enable FTP Port 21
I am trying to port forward a server using my public ip, but it doesn't work. Using a local host works, but when I try to scan my public ip, it says: "99.51.65.59 isn't responding on port 21 (ftp...
sam_reitich
Jun 04, 2019Tutor
the first line is 10.x and the second is 192.x
CrimpOn
Jun 04, 2019Guru - Experienced User
sam_reitich wrote:the first line is 10.x and the second is 192.x
Well, there's the issue. The Orbi is acting as a router creating 'private' IP addresses (192.168.x.x), but is behind another router which is also creating 'private' IP addresses (10.x) Three choices (1) put the Orbi in AP mode and create a port forward in the other router, (2) put the other router in 'modem only' mode and create the forwarding rule on the Orbi, or (3) give up.
I cverified this by configuring an FTP server on a Windows 10 machine and created an Orbi FTP rule pointing to it. Worked like a charm AFTER I dealt with Windows Firewall issues and figuring out what my "real" IP address on my phone was. (Hint: what the phone says is its IP address is not true, because the phone - like everything else in the world - is behind a NAT firewall.) This would not have been an issue except that I had set up the FTP server to allow only connections from the Orbi LAN and one outside IP address. I actually found my phone's IP address by looking in the Orbi log for what IP address was connected to my internal FTP server. Nice to see that Orbi logs that. Better have strong passwords if FTP is opened to the world (actually FTPS or TLS would be better, but I have not tried those).
Good Luck
- sam_reitichJun 04, 2019Tutor
how do i create a port forward to the router?
- CrimpOnJun 04, 2019Guru - Experienced User
sam_reitich wrote:how do i create a port forward to the router?
Well, that's the reason FURRYe38 asked about the brand and model number of the modem/router that the Orbi is attached to. Every router has a slightly different management system. Some ISP's allow the customer to access the managment interface of the modem/router, while others do not. One way to find out is to point a web browser to: "http://192.168.1.1". If it brings up a web page, then the modem/router is "visible". If there is no web page, then it may be locked.
Another way to investigate is to call the ISP technical support line and ask, "can you put my modem into "pass through mode"?
