MGWAPs
Dec 16, 2021Aspirant
How To Enable Remote Management on Orbi RBR850 with New Firmware V4.6.3.16_2.0.51
Hi, we updated our Orbi RBR850 firmware to V4.6.3.16_2.0.51 but can no longer enable REMOTE MANAGEMENT.
Is there a way to enable remote management now on this router with this new firmware???
Thanks
Thats enabled on the Orbi app and is now called Anywhere Access.
Netgear has set up a community forum specifically for the Orbi App product. Most of the people who watch that forum are more likely to have experience with Orbi App and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
We have updated and published a new KB about it:
https://kb.netgear.com/000058239/How-do-I-enable-or-disable-Anywhere-Access-on-my-NETGEAR-or-Orbi-router
https://kb.netgear.com/000064332/Why-is-Anywhere-Access-enabled-by-default-on-my-NETGEAR-or-Orbi-routerNetgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
Good Luck.
Thank you
